enable cli idle-timeout
Description
Enables a timer that disconnects Telnet, SSH2, and console sessions after a period of inactivity (20 minutes is default).
Syntax Description
Default
Enabled.
Timeout 20 minutes.
Usage Guidelines
You can use this command to ensure that a Telnet, Secure Shell (SSH2), or console session is disconnected if it has been idle for the required length of time.
This ensures that there are no hanging connections.
To change the period of inactivity that triggers the timeout for a Telnet, SSH2, or console session, use the configure timezone command.
To view the status of idle timeouts on the switch, use the show management command. The show management command displays information about the switch including the enable/disable state for idle timeouts. You can configure the length of the timeout interval.
The following command enables a timer that disconnects any Telnet, SSH2, and console sessions after 20 minutes of inactivity:
The cli keyword was added and the idletimeout keyword was changed to idle-timeout in ExtremeXOS 30.3.
Platform Availability
